Hi We have a 2020 Roxor . The power steering makes a noise when turning the wheels semi sharp. Is it the power steering pump belt which is tight or is the power steering pump failing? Fluids are full. Any thoughts? Thanks Bill
If memory is right it’s a 17mm wrench. Also check your t case and trans oil levels as well as diffs. they might be a tad low if they are doing things the same as 18-20. Some were very low, best to get on top of it before any damage is done. Just be sure to get the right spec oil in each box. Gl4 in trans and t case and gl5 in diffs.
