928dennis
Why are so many of us spending money on a front end issue that is not are fault? speaking of the front springs. I have a LE model that the dealer had added a windshield, big stereo with amps, so I would guess 200 pounds extra right over the front end. I had 1" of travel in the front! it would beat the crap out of you. I did the add a leaf spring but this is a Band Ad. Mahindra needs to address this, and put a spring pack on the front with a higher load rating. We should not have to spend are money just to do some mild off roading,they are sold as a UTV! I went around and around with Mahindra and got no where. I bought mine from Nash Powersports in Phoenix, they are a large dealer for the Roxor so you will find 8 to 10 on there lot at any given time. If you look at the Le models on there lot they set about 1" lower in the front then the std models, Mahindra needs to address this.
