My Roxor had been sitting a bit in the garage while I finished hooking up everything for the windshield wipers. When I started it up again it didn't sound the same. I drove it around for a few days and it struggled when accelerating. I decided it might be the fuel filer, changed it (there was no water in the fuel) and it helped. But now it has only been a little over a week and it is worse than ever. It is a 2022 and has 2k miles on it, oil has been changed twice now, proper levels. I am still getting boost pressure so turbo seems to be working. It idles fine. and used to cruse fine, but that is starting to be affected too. During acceleration it shakes stutters and sounds a little more clickity clackity than it used to. Valves? Injectors? Not enough fuel still? Any suggestings help would be much appreciated.
What wipers did you install and what year Roxor?
Curious because i hooked up the hardcabs wiper/washer on a new 2022 as per the instructions and have no power to instrument Cluster, other than alternator warning, no starter or lights.
i suspect it was caused by blue wire from supplied fuse/ relay box tapped onto the violet/ yellow wire before the inst. Panel fuse box.
the wiring diagram shows a v/y wire being for the oil pressure switch. That would indicated the wipers would not have power until the engine is running? Strange thing is i tested the w/w and they worked. This was with the engine off? Instructions are from 2018. Wondering if the wiring changed and if i,m right about the purpose of the blue wire connection to the V/Y wire?
Was afraid i fried something but after checking all fuses with bat disconnected and disconnecting big pwr plug by ECU on the second attempt after days, it started with normal indications on everything. Ran it for an hour, started it a couple times. After parking it everything went back to fail mode.
Seems like a relay. Start relay ohmed out ok. Why are the lights loosing power, for start?
Looking for the smartest electricianin town or i have an expensive boat anchor?
Sorry for the long rant. Appreciate you guys,
Ron
