arupp
I have the spall electric fan and thermostat in the box, ready to put it in. has anyone done this yet? If so could you share some pictures or tips on what you did? Thanks in advance.
ok thanks for the tip on removing the radiator first. What extra parts should I be concerned with acquiring? Is it worth the effort to do this?Remove the radiator, much easier. Also make sure you have the necessary parts to install the temp switch before you start.
sounds good. that adapter just showed up today, im going to try and do this next weekI'll take a photo in the morning to show you how I installed mine.
I am yet do install mine because I don't understand it eitherOk i am confused. why do we need a new thermostat and what temp is it? where are you guys installing the sensor? why do we need the adaptor fitting? Plan to order the fan this week but need to understand this stuff.
