2.7 Tune Results (with 4.10 gearing, video)
DrunkenSlug
NC
Here’s my 2025 mahindra roxor full send with 4.10 gearing and the stock 29” wheels. Full throttle, relatively flat. Does great! This is what it should have been from factory. Also this tune got rid of the weird stumble/shake I had around 1800Can’t wait for a lift and 35”. Great job to wade and the team at @dieselfreak.
Speedo is unaffected. I have it unplugged for the video since it's inaccurate due to my gearing being 4.10. Speedo on the phone is accurate.
l Roxor d
Idaho
That's great 👍 just sent my ECU in yesterday can't wait to get it back. Thanks for the video
Gabe
Louisiana
Will be great to see speed with the stock rear end! Thanks for posting!
BAM
Montana
Awesome! Looks go to me! Thinking of changing to 4:10 gearing as well. What speeds are you running at while idling in first and second gear?
Gabe
Louisiana
Does the stock speedometer not functional after tune ?
DrunkenSlug
NC
Yeah it works fine, mine was unplugged for the video so you guys wouldn't see the false reading (since I dont have stock gears). The phone gps speedo is accurate in the video
Why didn't you have the tire size calibrated with the tune?
Longslyde
Sauk Rapids, MN
Might be able to still do it the old fashioned way if you really wanted to correct it, by sourcing a different tooth count gear. The Roxor uses an 18 tooth that runs the electronic speedo unit on the tcase. The gear looked like a standard Dana 18 gear when I had mine apart, although I have not tried the swap, so if someone does and it works, please post it!
DrunkenSlug
NC
Update- driving it a bit more, feel great! BUT I’ve got a check engine light that flashes every few minutes. Constantly. Random amount of flashes, from 2 flashes to a solid 3 minutes of flashing, then it goes off again. But it always does it. Swapped a fuel filter just to see if that was it, nope. Wades investigating, said 2 of us have had this happen so far (so doesn’t seem widespread, I’m sure there’s tons of these sold so far).
BAM
Montana
I wonder if it has something to do with the boost from the turbo. I had an old ford truck with a 7.3l powerstroke and after we put a tuner on there the check engine light would come on briefly if we hit 20-25 psi boost at higher rpm’s. It would come on for a few minutes then turn off without any issue.
IndianaShadetree
Ferdinand, Indiana
Any update on the flashing check engine light? Mine did the same.. unplugged the water in fuel sensor and it didn’t happen again. Flashing CEL due to a sensitive water in fuel sensor has been common for me, but it sounds like you eliminated that possibility when you changed the fuel filter and it continued to happen. That is, unless, there actually IS high water content in the fuel.
DrunkenSlug
NC
Nah no update yet, wade said he’s working on a diagnostic tool for the 2.7 to figure out why a few of us have it happening. My water fuel separator is unplugged all together, I forgot to swap it to the new filter when I’ did the first filter change 🤦‍♂️. But nah, that’s not it. It’s weird, it only does it if you’re not giving it a good amount of throttle. Cruising it does it, accelerating it doesn’t.
IndianaShadetree
Ferdinand, Indiana
I’m certain Wade will have this solved very quickly. Keep us posted!
JB2133
Cedar Hill, TN
It's also happening to my unit - I emailed Wade last Tuesday to let him know and he said 2 out of about 54 (at that time) have reported this issue. Im confident he will figure out if there is a true issue or not but I did reach out to him this AM just to confirm it is still happening, so he can maintain an accurate count of those affected. Personally, the light does come on (flashing like you said) around 25-2600 RPM, typically when accelerating (nothing crazy, the couple last MPH to the speed limit so I would say it is at the top end of acceleration) but when I back off the throttle and re-engage it seems to go away. Personally I feel comfortable continuing to drive it as I havent seen/heard any noticeable issues, unless Wade eventually advise against it.
Just wanted to jump in here to let you know of a similar situation (heck, I might be the 'second' of that number 2 you were told!).
John
DrunkenSlug
NC
Hey John, just saw a post on the mahindra group on Facebook. Lots of people chimed in saying they had the same issue we were having, wade chimed in and stated he/they knew the issue and were working on a fix already. Fingers crossed. I’m also still driving mine, I don’t think it’s doing damage of any kind. Still feels fine.
John
DrunkenSlug
NC
Wade sent return labels and emails to fix the tune for all of us 2.7 owners. Said they have it fixed now. I’ll be sending it back in a few weeks for the update.
Gabe
Louisiana
Ok. Thats great. If you have any details on it that would be great. I held off just for a bit to make sure it got worked out. Also, using the Roxor hunting right now.
lost1wing
Georgia, LaGrange
I would be interested if I could plug in a scan tool to read and reset codes, if nothing else. Are we still unable to scan the ECU after this mod?
