instrument panel problem
gbarney
Yakima, WA, USA
2018 roxor. battery indicator is only light to function on panel. If I pull fuse after key is turned on panel comes on, fuel gauge works , speedo works, presume all functions work. except odometer and hours read, fffffffff so I can't tell how used the roxor is. Any insight to cause and cure welcome.
Tach also comes on after fuse is removed and reinstalled.
Contact Kinetixrcr he fixed my gauge. Not sure you have the same problem but I would certainly contact him.
